NeilTruter
Re: engine running warm but temp guage at normal
Nick Gibson wrote:The water/coolant pump in a V6 pajero is run by the Cam belt, the belt is reversed over the pump pully and runs on the back/smooth side of the belt, not the side with teeth for the Cam gear. It stands to reason that if the tension is low the belt could posibly slip on the water pump.
Aaah, understood, but then is it not possible for the belt to slip one teeth or so ? hope the mech checked the timing afterwards.
Keenan
Thanks for the comments.
I am looking into putting an after market temp gauge where my inclineometer is as its leaking and its not a tool I use. I know there are some topics on the forum regarding this. I will try find them to help me out.
Thanks again,
Keenan
