Page 2 of 3
Re: Engine light coming on - again!
Posted: Mon Jun 01, 2015 6:17 am
by Nick Gibson
Kennekam wrote:O no! The dreaded engine light came on again four times today. When going up a steep hill the gearbox downshifted and the engine light came on with commensurate power loss. This is despite a turbo rebuild in December.
Not sure what to do now....
Did the pajero go into limp mode? Did the light extinguish itself when backing off the accelerator, or did you have to restart the engine? Which error codes come up when you do the DIY code scan?
Check if all your hoses are still attached, sometimes the hoses jump off the turbo or intercooler if the jubilee clamps haven't been tightened properly. Also see if the little hose from the wastegate actuator to the turbo is still attached.
Posted: Mon Jun 01, 2015 7:53 pm
by Kennekam
Yep, the moment I lifted my foot, the light went off and the turbo kicked in again. Last time the symptoms were the same and the error code said it was an over boost. The car is going in on Thursday
Posted: Tue Jun 02, 2015 8:19 am
by Nick Gibson
Kennekam wrote:Yep, the moment I lifted my foot, the light went off and the turbo kicked in again. Last time the symptoms were the same and the error code said it was an over boost. The car is going in on Thursday
OK, sounds like an over-boost pressure issue (I have had it before too) . Keep us posted to the outcome.
EDIT:
What was replaced in the turbo rebuild? Was a brand NEW waste-gate actuator fitted? Sound like this could be the culprit...
Posted: Sun Jun 07, 2015 8:07 am
by Transkeicowboy
has anyone checked the EGR pipe for blockage?
when the warning ;light on my DiD kept coming on intermittently the mitsu mechanics couldn't diagnose the issue. eventually led to one of my pistons breaking a big bill from a rebuild.
the EGR was extremely blocked.
soon as I hear of guys with the engine waring light coming on this is always the first thing I tell them to check.
my problem occurred at around 190 000km
good luck sorting out your issue
Posted: Mon Jun 08, 2015 5:08 am
by Kennekam
The waste gate actuator was cleaned. I understand that there are two versions. one is mechanical, the other is electronic. The car is going in on Wednesday to have it checked.
Will keep you posted.
Engine light coming on - different code
Posted: Mon Jun 22, 2015 10:34 am
by Kennekam
It appears as if it is a different fault code 13 now. The last time it was turbo over-boost, now it it is air intake temperature. Looks like it is difficult to diagnose the cause.
Posted: Wed Jul 15, 2015 11:30 am
by JohnG
From what i have seen on other forums this could be a carboned up manifold/egr that causes a lot of these types of issues
Posted: Wed Jul 15, 2015 11:57 am
by Kennekam
JohnG wrote:From what i have seen on other forums this could be a carboned up manifold/egr that causes a lot of these types of issues
The EGR and manifold were checked. The wastegate actuator was adjusted which seemed to solve the overboost problem.
Posted: Mon Aug 03, 2015 12:21 am
by Kennekam
Sorted. The actuator was replaced. It appears that when the turbo was rebuilt in December, the actuator rod was found to be bent and was straightened. But there was obviously something else wrong.
The turbo was boosting too soon at low revs. So when the engine was pushed going uphill, it over boosted. Now the engine seems much smoother and seems to have more power at 120kph. It also 'chirps' much less when accelerating.
Posted: Tue Aug 11, 2015 1:19 pm
by Kennekam
One week later, lots of steep hills and no engine light. Yay!
