Page 2 of 2
Re: Chip
Posted: Sun Jan 24, 2016 10:07 pm
by Nismo
Tim,
Did you work it out on actual fuel used or checked on the OBC ?
I chipped my 2009 3.2 also at Dastek and noticed the car would show round 10l/100km but actual fuel usage worked out to 13l/100km.
Re: Chip
Posted: Mon Jan 25, 2016 1:36 pm
by Tim S
The consumption I noted was off the OBC, but I checked a few times when filling up comparing trip meter mileage vs litres put in and this also was around the 10l per 100km mark.
Re: Chip
Posted: Tue Jan 26, 2016 9:00 pm
by Thysie
Roelf_le_Roux wrote:Hi Charl, I see this is your first post. Welcome.
Your Pajero model is commonly referred to as Gen3 and the following one obviously Gen4.
Your diesel pump isn't electronic, but mechanical. The engine management is however electronic. The pump has a piston for each cylinder and it thus delivers a squirt of diesel directly into the cylinder (through an injector) to initiate the burn.
The Gen4 with the common rail injection has a high pressure pump that delivers fuel constantly into the common rail "reservoir", where it sits under extremely high pressure. This high pressure fuel extends right to the "back" of the injectors. Electronic signals from the ECU then informs the individual injectors on when and how to open and allow fuel into the cylinder.
To chip or not (or which chip) has been heavily debated. I'm not going to go there.
My father in law and I had a long chat about what the common rail thing might be, thanks for shedding light on the subject for us. Now I know something he doesn't... For once... Hahaha
Re: Chip
Posted: Sun Apr 24, 2016 12:21 pm
by naudeo
Hi everyone , I bought a 2nd hand 2001 LWB 3.2 which I understand was chipped . how do I find out what chip was installed ?
What Gen is a 2001 ?
thanks
Ono
Re: Chip
Posted: Sun Apr 24, 2016 4:32 pm
by Theodorus
Thank you for the info im going to put a chip had one in my Hilux big diff now i know its ok to
