Page 14 of 19
Re: The story of Casper 3.2Didc GLS LWB 2009
Posted: Wed Jun 07, 2017 6:26 pm
Kurt
Thanks yes, I did think the globes were a bit pricey but Mitsu was on my way to work and supposed to have the right stuff on the shelf so rather just went there. Luckily they had stock
In any case my recent experience with Oriental plaza led globes just made me rather go Original Equipment again for a bit of sanity.
Posted: Sun Jul 16, 2017 9:15 pm
by JTEC
CATS wrote:So decided that the cat converter has done enough work at 160000kms and had it taken out. I don't think it was really radically blocked. Will see if it makes any difference to performance or fuel economy but not expecting miracles. Just helping Casper breath a bit easier and getting rid of old gasses easier.
Cats could you maybe help clear this up for me..correct me if im wrong but the Gen 4 injection is controlled by the ECU where the Gen 3 is controlled via mechanical timing. If you remove the cat from the Gen4 , the ecu will get incorrect mixture readings and will try to compensate for this change and begin to run rich. I know this happens on petrol engine engines and usually remapping is required but dont have a clue with Diesels. Have you noticed a consumption change? Also is there any effect on the Gen 3 ?
Jtec
Posted: Mon Jul 17, 2017 10:01 pm
Jtec
On both my previous gen 3 and current gen4 I cant say that I noticed a material change in power or fuel consumption after cat removal. Definately more noticable turbo whistle and more pungent diesel smell from exhaust though.
Does seem to rev easier but might be imagination.
I dont think the gen3 or early gen4 has sensor on or after the cat, so it will not pick up anything different on the ECU as there is nothing to measure. On later models there are apparently sensors which will throw fualt code if you decat.
Posted: Tue Jul 18, 2017 8:59 am
by JTEC
Jtec
Ok great thanks. I have been keen to remove the cat but was a little concerned. Just another quick question, would you recommend blanking the EGT ?
Great thread btw, really enjoy reading it. 8-)
Posted: Tue Jul 18, 2017 11:32 am
I blanked the EGR and would advise doing that. On early gen4 before 2010 this is possible without a fault code. Try and block it at the exhaust side before the actual EGR flap/butterfly to prevent it from getting gunked up otherwise it will get stuck some time and will throw fault code even though it is not actually doing anything anymore.
Posted: Thu Aug 10, 2017 8:32 pm
Had remap and 170000km service done at Mitsitech. Also flushed auto gearbox and and replaced gearbox filter and gearbox oil. The gearbox was only done as extra maintenance as I tow every now and again when I go away and still feel a bit weary of these autoboxes after having driven a manual Pajero for so long.
MAF sensor was also found to be faulty and was replaced.
Must say it feels more powerfull. Will check fuel usage but can't wait for the real test when I go camping again.
Attached is the dyno report.
CATSImage
Posted: Fri Aug 11, 2017 7:23 am
by KurtG
Sounds good Cats, hope you see a real improvement when towing.
Posted: Fri Aug 11, 2017 7:37 am
by Greg_SA
CATS wrote:Had remap and 170000km service done at Mitsitech. Also flushed auto gearbox and and replaced gearbox filter and gearbox oil. The gearbox was only done as extra maintenance as I tow every now and again when I go away and still feel a bit weary of these autoboxes after having driven a manual Pajero for so long.
CATSImage
Nice :)
What did they charge for the MAF? Part number 1525A016 ?
Ah, just saw your other post that you got a 2nd hand one :)
Posted: Fri Aug 11, 2017 9:19 am
Second hand they charged R2500 for the MAF sensor, which was ouch after the service, dyno and gearbox service, but I think in line with pricing in the market.
Posted: Fri Aug 11, 2017 10:23 am
by Greg_SA
CATS wrote:Second hand they charged R2500 for the MAF sensor, which was ouch after the service, dyno and gearbox service, but I think in line with pricing in the market.
Definitely better than R11k from the dealers :)
I still might consider replacing mine, even though it seems fine after cleaning.
