Was onto my third idler bearing in a year.(water crossings).found an idler bearing off a toyota hilux had the same diameter/offset/shaft size .but it had a simple ballrace cheap to replace and only held in with a circlip.problem resolved
and the bearings are under 10 dollars to replace
Which Hilux engine?digger wrote:Was onto my third idler bearing in a year.(water crossings).found an idler bearing off a toyota hilux had the same diameter/offset/shaft size .but it had a simple ballrace cheap to replace and only held in with a circlip.problem resolved
Part number(s)?
Photographs?
sorry about reply getting over earthquake will send details and photo soon
