I misread your name as Roelfie Roux, now I see it is Roelf leRoux. My humble apologies , no slight intended in my answer and adressing you as Roelfie.
Thanks Bernard, I feel somehow vindicated by your post. Here I was thinking it is only me.
I am going to do some testing of other shocks as proposed in other posts ( Davidvan ,I will mail you shortly, Tnks for mailadres).
I am wondering though if this is not a coil issue, as the rebound is just too sharp. I have always liked a soft spring with a decent shock, has worked in other rigs I have owned , but it was somehow easier to get it right.
My thinking is one needs a longer (not just taller) coilspring .Perhaps a slightly bigger diameter over the whole distance from top to bottom and which tapers to the correct diameter at the ends to fit the struts and cups. Or it can be same diameter , but with one extra turn to gain more height, instead of having the same amount of turns with wider spacing.
I have seen other posts where local spring manufacturers' efforts were not so good. Were those for modifying existing coils or the manufacture of new ones?
Has anyone had coils manufactured by a local springworks which actually works?
