Hi Greg,Greg_SA wrote:Hi Dave,DandB wrote:Hi Greg,
We have just done a shortened Lesotho trip because of lack of power.
After leaving Durban the Paj (3.2 DiD LWB 2010, 125000kms) seemed a bit lazy, by the time that we were at 1000m altitude I was conscious that I was down on power. By the time we got half way up Sani Pass (2400m) there was not much I could do except change manually in the hope that I could keep it in the power band!
Subsequently, I've asked Mitsu to assess the problem & was told that as there were no fault lights there would be no diagnostics. One tech suggested that the air cleaner was blocked (It had done about 6000kms since a service change, of which about 300kms have been on dirt roads) everything else seems good - temperatures etc.
How does this compare to the symptoms that you have seen?
Dave
Sounds similar.
My Pajero just felt like the throttle wasn't working. Everything was smooth, but whether I had my foot flat or at 1/4 throttle, it felt the same. Cleaning the MAF solved that immediately.
To test a faulty MAF, you can temporarily unplug the MAF, and your power should be back to normal (or much better). If you keep driving with the MAF unplugged, you'll eventually get a CEL (engine light).
It isn't dangerous to run with the MAF unplugged temporarily.
Maybe give that a try?
Thanks for the info.
Bought a can of CRC MAF cleaner & sprayed about 25% of the can into and around the sensor. Appears to have cured the problem.
You refer to the OBD2 - which one do you prefer?
Dave
