Re: 2005 Pajero DID head cracked on 130000km
pierreandre wrote:
4ePikanini wrote: would much rather spend the money on a coolant loss alarm (my pajero has oil pressure sensors and low oil alarm so I'm redundantly covered there)
Did you install aftermarket sensosrs?
No. My 2001 Di-D GLS came standard from the factory with low oil level sensor. Maybe because they knew how prone the oil pressure switch was to failure (when it fails it spews oil and also doesn't allow it to trip the low oil pressure light :shock: ), so the low oil level is a life saver - it saved my engine a few weeks ago!
https://www.pajeroclub.co.za/forum/view ... =55&t=1856
Transkeicowboy
what markings are you referring to in your post above with the photo of the piston sleeve? I think mine might have similar marks but will have to go and look again.
