Page 5 of 5
Re: Gen 4 DID NO POWER
Posted: Thu Sep 10, 2015 7:28 pm
by Josef9177
Hi cats ..is that the map sensor? I was under the impression that the map sensor is the one on top of the filter? And the one in the picture is boost pressure sensor which I have replaced as well? I don't think that tube is blocked because when I changed that sensor the power came back. Anyways would check that tomorrow
Posted: Thu Sep 10, 2015 8:38 pm
Josef
To be honest. I dont know which sensor it is but I think you are right. I just read on the thread that I attached that the vacuum pipe to it might get blocked leading to low power on gen4.
Posted: Thu Sep 10, 2015 9:22 pm
by Nick Gibson
Josef9177 wrote:Hi cats ..is that the map sensor? I was under the impression that the map sensor is the one on top of the filter? And the one in the picture is boost pressure sensor which I have replaced as well? I don't think that tube is blocked because when I changed that sensor the power came back. Anyways would check that tomorrow
Hi Josef. MAP is the Manifold Absolute Pressure sensor, and is what CATS is referring to. That measures the boost pressure relative to atmospheric air pressure, it normally resides next the the fuel filter and is connected to the intake manifold via a thin rubber tube.
As far as I can see, the sensor your are referring to on top of your air filter is a MAF sensor, or Mass AirFlow sensor which measures the amount/volume of air entering the engine at a given moment in time.
The ecu uses these two sensors to calculate how much fuel to inject into the engine.
Gen 4 DID NO POWER
Posted: Fri Sep 11, 2015 7:21 am
by Josef9177
Finally the issue got diagnosed!!!!!
This rubber hose from the manifold was disconnected
None of the sensor was faulty ...Dumb Stupid mitsu India ...6months of frustration ,blood ,sweat and wasted around US $ 900 on this issue
Thanks much all for ur comments and cats I owe u man Image thanks nick gibson without you stupid mitsu and me never knew what is map and maf sensors Image
Imagethanks all once again
Posted: Fri Sep 11, 2015 7:52 am
EXCELLENT!!!!
Posted: Fri Sep 11, 2015 9:35 am
by Roelf_le_Roux
Great news, but unbelievable.
Techies are so addicted/reliant on computer readouts that they fail to physically check the basics as well.
Posted: Fri Sep 11, 2015 12:59 pm
by KurtG
What an awesome outcome at the end, pity about the waste of time and money. And well done to the Pajclub SA guys for helping! :)
Posted: Fri Sep 11, 2015 3:40 pm
by Nick Gibson
Good news!
Posted: Mon Oct 19, 2015 1:02 pm
by herylanto
No power
Posted: Tue Oct 20, 2015 9:06 am
by Josef9177
Whts ur fault code
