Waterpump 6G74 Engine
Posted: Thu Aug 19, 2010 5:47 pm
Hi Guys
Once again I am in need of the advice of some our engine fundi's. I am having my 200 000km service done (plus cambelt, etc) and in line with the conventional wisdom on the forum, I am having the waterpump replaced as well. The problem is to get hold of the correct pump. The dealers have at least 3 different pumps for the 6G74 engine in their catalogue, all of which are different to the present one on the engine! We eventually sent them a photograph of the fitted pump but although it looks the same, the pulley size of the one they supplied is 10mm smaller in diameter (60mm as opposed to 70mm) than the present pump.
What to do now? Can we fit this pump? The rev's at which it runs will obviously be higher than the old one; will this matter? Will this cause the engine to run slightly hotter as the water will be circulated quicker? And what side effects might that have? Could there be other side effects we haven't thought of?
Can anybody help pse?
George Snyman
PS: The smaller pulley now also necessitates a smaller (shorter?) cambelt as the tensioner pulley apparently won't be able to take up all the slack.
George Snyman
