Triton Engine VS Pajero
Posted: Thu Aug 26, 2010 8:08 am
by 4x4 Outthere
Please tell me what is the difrence between the Triton 3.2 Di-D motor and the one that is in the Di-D Pajero. Will it fit to my Pajero?
Re: Triton Engine VS Pajero
Posted: Thu Aug 26, 2010 9:19 am
AFAIK they are identical but the extras and engine mountings might be different.
But........ as I have come to know mitsubishi I wouldn't be surprised if it is a direct bolt on swap.
Posted: Thu Aug 26, 2010 9:23 am
The engine blocks are identical, but as Marius said, some peripherals might be different, eg
- engine mountings
- AC pump
- alternator
- vacuum pump
- inlet manifold
- inlet ducting
- outlet manifold
- water hose connections
- etc
Posted: Thu Aug 26, 2010 11:08 pm
by Gerrit Loubser
Thinus, just be aware that the Triton uses a common rail injection version of the DiD, while the Gen 3 DiD has a more old fashioned electronically controlled rotary injection pump system. The engine ECU in your car most certainly won't work with the common rail motor, so you will have to transplant the Triton's engine as well as all the electronics (ECU, loom, sensors).
Posted: Sun Aug 29, 2010 12:49 pm
by 4x4 Outthere
Hi Guys.
Thanks for the Info
Next Question?
I can get a 2008 low Km motor.(Roll Over) Mine is a 2000.
What hiden surprises are waiting for me if I should buy that motor?
Posted: Sun Aug 29, 2010 5:49 pm
by Gerrit Loubser
Thinus, that would be a Gen 4, if I am not mistaken, so it would also have a common rail version of the DiD motor.
A transplant might still be possible, but you would have to get all of the electronics (ECUs, sensors, looms) and be ready to be a pioneer. Perhaps it would be best to buy the whole wreck, to transplant the motor and then to sell what is left as parts.
Posted: Sun Aug 29, 2010 7:55 pm
by 4x4 Outthere
It seems that the old Transvaal law is Back
Posted: Mon Aug 30, 2010 9:24 am
4x4 Outthere wrote:I can get a 2008 low Km motor.(Roll Over) Mine is a 2000.
How much?
Posted: Mon Aug 30, 2010 6:34 pm
by 4x4 Outthere
35000.00 for the Motor.
I am in Eretria at the moment will find out what the loom and management system will cost when I get back to SA Ja plus the Labour. I recon close to 50k
Posted: Tue Aug 31, 2010 7:31 am
If you can get the engine with all the electric / electronic bits for that price, it's a bargain.
Don't under-estimate the labour cost. If a workshop does it for you, it might not be viable.
The only way is to get a lump sum price for the completed project, not an "open ticket" hourly rate.
