Glow plugs turn off prematurely
Posted: Tue Sep 21, 2010 1:03 pm
by Goodbye Toyota
Good day to you all and thanks for taking the time to read my first posting.
I'm having some smoking problems after cold start up until the engine is hot on my 1998 4m40 Pajero. I hooked up a 12 v light to one of the glow plugs and verified that with a cold engine, the light goes out about 15 seconds after the engine fires up. I understand the glow plugs typically keep 'glowing' for about a minute and a half until the water temp starts to rise. This premature turning off causes a lot of dark grey smoke and heavy vibrations of the engine unless I rev it up. I have cleaned the contacts from the water temp sensor and the ones that go to the two relays, but not sure how to actually test the relays. (Glow plugs are new, aftermarket) Could I possibly hot wire the glow plugs to a switch inside to manually turn them on and off? Thanks for any suggestions. Dave
Re: Glow plugs turn off prematurely
Posted: Mon Oct 04, 2010 12:38 pm
by digger
check power wire connection and rail connections.remove plugs and check.if all ok fit 1x glowplug upside down on rail (to view)connect earth and turn key on to check operation (should be cherry red)
