Blister
WHERE IS THE OIL PRESSURE SWITCH LOCATED?
I am in the process of fitting a mechanical oil pressure gauge but need help to located where the oil pressure switch are located or even better if someone could advise where else I could fit the gauge's adaptor on the engine block?
I have already replaced the elevation/hydrometer gauge with a Volt Gauge (with dp switch to monitor both battteries thus I am tossing out the inclinometer, as I know that the feeling in my "ass" is far more accurate when it comes to knowing if and when the van is going to fall over :twisted:
digger
Re: WHERE IS THE OIL PRESSURE SWITCH LOCATED?
Save the money for some more steinlagers to fit in the fridge
tonton
Blister wrote:...I am tossing out the inclinometer, as I know that the feeling in my "ass" is far more accurate when it comes to knowing if and when the van is going to fall over :twisted:...
Carefull - when you do desert driving and the wind comes up, you can by rather disoriented. Sometimes your senses tells you you are reversing whily you are moving forward due to the movement of sand in the wind.
ghost_traffic
Back to the topic. :twisted:
My oil light flickers when driving slowly and stays on when the vehicle comes to a stop, but as soon as I pull away and travel normally, the light stays off.
I think I need to check the oil pressure switch. Any other ideas? :?:
Nico.
P.S. I have already checked oil level. ;)
tonton
ghost_traffic wrote:Back to the topic. :twisted:
OK, so where's the oil pressure switch? :lol:
ghost_traffic
Precisely! I need to know the location of the switch so that I can check it. :lol:
Can the pikanini's please stand up. ;)
Where is the oil pressure switch? :mrgreen:
Nico.
Blister
I got the info from the Stealers! :evil: Its in front of the oil filter
Only problem is tha Brian at Tygervalley was too lazy to give me the specs cause I want to fit a t-piece to fit the gauge as an addition to the oil pressure sensor
manual oil gauge.pdf
(80.95 KiB) Downloaded 487 times
tonton
Blister wrote:I ...Only problem is tha Brian at Tygervalley was too lazy to give me the specs cause I want to fit a t-piece to fit the gauge as an addition to the oil pressure sensor
Aslam
Talk to JJ. He is the best!
Blister
Hi Anton!
Got your pm and I did ask for him but he was/is on leave
Aslam
