greetings all.
Does anybody know where all the different coloured vacuum pipes are supposed to go...ie where does each one actually connect to
Is there a diagram somewhere that I can use to compare what they should be like?
I saw that there are 3 pipes going out from the vacuum pump, 2 go to the left side under the battery tray solenoids and one goes to the right side to another set of solenoids underneath the air filter housing.
kind regards.
Zoobie
