I am looking to import Denso spark plugs for my Pajero. The plug is the Denso Iirirdium power plug. I know lots of gadgets claim more power but Denso is an established company who also manfucatures OME parts on the Colt and Pajero(fuel pump on my vechicles is Denso). the only backdraw here is the price which is abit steep but i'm willing to take a chane since it will also last longer than normal plugs. Some write up:
Iridium plug
14mm Thread Size, 19mm (3/4") Reach, 13/16" (20.6mm) Hex Size, Gasket Seat, Resistor, Removable Terminal Nut, 0.4mm Iridium Projected Center Electrode, Tapered Cut U-groove Ground, .043" (1.1mm) Gap, Heat Range 16
Denso's Iridium power spark plugs help your vehicle achieve unparalleled performance. It alters the belief that a mere spark plug can add power and mileage. This is done by combining an ultra-fine 0.4mm diameter Iridium center electrode with a tapered cut U-groove ground electrode. Iridium conducts electricity better than platinum, however what makes it exceptional is it's also 6x harder and 8x stronger than platinum. Because of this, the center electrode can be machined down to 0.4mm. This ultra-fine iridium center electrode provides superior ignition performance during acceleration and top cruising RPM. The U-groove ground electrode creates a larger, brighter flame kernel. The tip of the ground electrode has been tapered which further improves firing performance by reducing quenching. All of these features combine to give more horsepower to your motor.
The price depends on the quantity and postage. The price per plug goes down when ordering more than 50 but the postage goes up considerably. Roughly you look at R125 a plug. Is anyone interested and please I'll also appreciate your input and comments on the plug itself.
