Electric Window Mechanism
Posted: Mon Jun 20, 2011 9:13 am
by Slug3d
My drivers electric window is starting to play up. The electric system still works but the 'one-touch' open and close feature has decided its had enough.
When you hold the button to close the window it will roll up to 1/4 closed and stop. You then have to let go the button wait a second and do it again. It will then go to half closed and stop, at which point you must repeat the 'let-go' step. It stops again at 3/4. Then it will close fully.
Until the entire system stops working completely I can't justify taking it in to MM, but it is highly irritating.
If anyone has experienced similar and knows what the issue is some light on the subject would be appreciated.
Re: Electric Window Mechanism
Posted: Sun Aug 02, 2020 9:19 am
by bradley
Try to reset the system, push the window switch to go down,each time it comes to a stop push the button again until it reaches the full down position.Once the window has reached the full down position push the button again and hold button down for 5 seconds,repeat the same procedure for up position until fully up and hold button for 5 seconds.This tells the system where the full down and full up positions are,then try the auto close ore open function.
