Freeflow Exhaust
Posted: Mon Jun 20, 2011 12:04 pm
by Jenki
I've read about Freeflow exhaust here sometimes but still don't understand what does it means.
Is it some new system or techniques or some sort of tuning?
Maybe I have stupid questions but could be anybody explain this for me/
Thank you in advance
Re: Freeflow Exhaust
Posted: Mon Jun 20, 2011 12:34 pm
by Cas
Please feel free to correct if I'm wrong
The free flow is to let exhaust gasses escape with a certain amount of back pressure required for optimal performance.
Eg,if you increase pipe diametre from 55 to 63mm,the motor would run a bit better,but increase to 70mm would result in loss of torque.
Hope this helps.
Posted: Mon Jun 20, 2011 1:11 pm
Freeflow means there is no restriction through the length of the exhaust.
A free flow exhaust usually refers to the silencer box.
The free flow model has a straight through pipe that is perforated to allow sound to be absorbed like this one.
A normal exhaust has resonator chambers and the exhaust design lets the gasses move through a maze of passages which in turn muffles sound, creates back pressure and robs power in certain conditions and rev ranges.
Posted: Tue Jun 21, 2011 9:40 am
by Jenki
Thank you for information. Do you know about any company which is providing this kind of exhaust for Pajero 3.5V6 24v?
I'm using K&N air cleaner from beginning, maybe exhaust will help my car as well.
My idea is to use DENSO Iridium spark plugs and NGK ignition cables as well.
