Freshman
Bad reception
Hi all,
I've been moving my Garmin Nuvi 300 from car to car, the Pajero being the 4th.
Each time I have no problems with reception but this time I keep on getting low satellite messages.
When I hold the device out the window it connects fine.
Strange as I have it in the same place as previous cars.
I tried to move in across my dash but still getting bad reception.
Is there a reason for this, maybe something causing interference?
Pierre
Re: Bad reception
It's most probably the type of glass used in the windscreen glass, which reflects the signal in stead of letting it through the windscreen.
paw_by_paw
Re: Bad reception
Freshman,
I have the same problem with my Nuvi 610. This started after upgrading in December to new version maps.
After much talking and bulls*t from outdoor warehouse where it was done I got hold of Garmin in JHB and explained the problem.
Their comment was that these guys loaded some other thing (something about chipping or something like that) that was not supposed to be loaded with software upgrade and this will cause poor reception as well as slow reaction times. So on Saturday I am off to their offices to upgrade once more with 2011 mapping and the correct software settings. Mine was so slow I passed turn-offs by 300 meters and the thing started screaming RECALCULATING!!!!!. Enough to make you want throw it out of the window :evil:
New mapping and software reset or reload is R350-00 bucks. Will see after that what the response will be.
Freshman
Re: Bad reception
Thanks - I will take it to Avnic Trading in Durban for an upgrade.
Else I'll cut a neat hole in my windscreen with a hole-saw :)
Freshman
Re: Bad reception
As usual throwing money at a problem solves it :(
It seems I have a UV coated windshield which also blocks the GPS signal, so I need an external antenna like the Garmin GA 25MCX Low Profile Remote antenna or that hole-saw...:)
Re: Bad reception
I know that problem is common on the Land Rovers, with their flat windscreens. Never heard about it in a Paj. I've used two different models in my Paj, even two next to each other, and never had a problem. Possibly it is the software...
GertM
Re: Bad reception
I also think it is some sort of coating on the windscreen that's the culprit'
Cars with rain sensing winscreen wipers have a coating on the windscreen that triggers the wipers to start working. This coating also block out the GPS signal.
paw_by_paw
Re: Bad reception
GJM,
Sorry to correct you here but the rain sensitive wiper system works on a similar system to these outside spotlights with movement tracking.
The device is situated behind the rear view mirror and it actually works on the movement of rain drops on the window .
It can be adjusted for sensitivity same as for the lights on the wiper handle.
I was fortunate to have this seen as once SWAMBO'S Jetta's windscreen was replaced and after the thing was going haywire due to the sensor plate being installed the wrong way down.
If you have this new winscreen protective sheeting on you will probably experience that result with a GPS as I think that might interfere with signals.
GertM
Re: Bad reception
Thanks for that. It just shows that you should never believe everything you hear....
Freshman
Re: Bad reception
Since I started this post, let me report back on a good note:
The no reception turned out to be my plug-into-the-lighter-mp3-FM-Tuner gadget set to 87.5 interfering with the GPS.
Found out by chance when I unplugged the music player gadget to charge my phone.
So I changed the frequency to 88.1 and it worked. GPS 100% :)
