4ePikanini wrote:does the vehicle use coolant?
If not don't stress too much. It is an indirect engine and in the cold it does start more difficult than the new direct injection engines. The white smoke may just be a puff on unburnt diesel.
Do you start it without depressing the accelerator pedal?
How long does it swing before it takes?
Try to make the engine warm with lots of hot water or a heater when it stood overnight and see if it does the same. (Try to cycle the glowplugs 4 times before starting and see if it reduces the smoke)
Thanks - I have tried both with depressed pedal and without - same result when cold but not so much smoke in warmer weather, and occasionally none at all. It starts easily although in these lower temps (7C ish) one cylinder seems to miss for a few seconds.
What do you mean by cycle the glowplugs - do you mean heat until light goes off, release, repeat and so on four times?
John
