My 2006 SWB 3.2 DiD started showing the following 'symptoms':
- heavy on fuel (get approx 450 km on a tank...
- feels as if I am loosing power when accelerating when going up a hill
- when driving at steady speed say 130km/h and I want to overtake a car, the auto gearbox does not step down for long long enough so I can get enough power / speed to do so; the revs would go up to 3500 rpm or so and then it would immediately go back to just under 3000 rpm - this was not so when car was new(er).
[tab=30]"Injector nozzles" - this includes the nozzle spray pattern, opening pressures, tip condition, etc
So, this was never done by Mitsubishi - is that acceptable?
I now have the following questions:
- [1]can these symptoms be pointing to an issue with the pump, injectors, etc?
- [2]if so, can this type of repair / service be done by non-mitsubishi agents?
- [3]I was informed by JJ at Mits Durbanville that only Alan Black is authorised to work on their pumps...??
- [4]can the injectors be tested by a good diesel technician?
- [5]can one replace the injectors and if so, what is the cost?
- [6]does anyone know of a good place in Cape Town where i can have this pump-issue looked at?
- [7]any other advice will be appreciated.
Thanks for your assistance..
