Please help with Error Codes - 2001 3.2 Di-D Pajero
Posted: Tue Oct 04, 2011 11:00 pm
I have recently experienced a problem with my pajero. After driving a few kms in 2H, all green lights will go off on the dash and the centre diff will start to flash. I can then do what I like with the short lever, it stays flashing.
Restarting the car solves it for a few kms and then the problem comes back.
If I drive in 4H the problem never occurs.
Even after troubleshooting for a few hours I can't seem to find the issue. It may be intermittent so I scanned the car (manually by bridging OBD port connector1 to ground and reading flashes) and need help on what these codes mean.
PS : To read codes, connect terminal one on the OBD port to ground and read the CEL flashes. The first long flashes are the tens and then the following short ones are the single digits - ie. 3 long and 2 short = 32) pauses are in between codes
- do this at own risk
The thing that confuses me is that I get codes from other flashing lights as well.
The CEL gives me codes - 49
The ABS light gives me - 22
The Neutral light (Auto) - 52
The centre diff light - 34, 35
