Gen3 Front & Rear Shocks - Tips On Replacement
Posted: Tue Dec 06, 2011 9:56 am
Morning all,
Next job is to replace rear and front shocks, just wanted some confirmation on the steps needed, as far as i can tell:-
Rear: (Done plenty on other cars before, but never fronts)
Jack up car - how far to maximum suspension travel or half way then adjust with a bottle jack on the lower arm to get movement ?
Plenty of plusgas on top nut and bottom bolt/nut/pin
Remove top nut first ?
Need to grip shocker with anything to stop it turning for top nut, pipe wrench etc ??
Remove bottom nut and tap bolt out - is it likey to stick need to tap/drift out with a suitable drift (hammer !!)
Assume shocker is now free to remove - just slides up and out
Replace as above but with plenty of copper ease.
Fronts:
Not looking forwards to this one - me thinks its a PIA to do at home ?
Plenty of plusgas on top nut and bottom bolt/nut/pin/everything else?
Undo 3 nuts holding top of suspension tower in place?
Remove bottom nut and tap bolt out - is it likley to stick need to tap/drift out with a suitable drift (hammer !!)
Assume shocker is now free to remove - just slides out - plesae tell me you do not need to remove the upper arm bolts at both sides!!!!!!!
Spring compressors onto tower and compress spring ??
Remove shocker
Any advice welcome - ideas on time per side?
Most concerned about the fronts, willing to have a go at most things but limited in time and kit so may just put it into garage to do fronts if its complicated or likley to need more work than i think above.
Thanks in advance
Fronts:
Remove shocker
Thanks in advance
