Eng light 3.5 blister auto .
Posted: Mon Dec 26, 2011 11:15 am
by robwright
My pajeros eng light comes on after about 15 min of driving . Then goes into limp mode eng light on an running rough . Won't rev at all until I switch key off and wait 5 minutes . Fault code says 92 any help on codes on 3.5 blister 97 model .
Any assistance appreciated .
Re: Eng light 3.5 blister auto .
Posted: Wed Dec 28, 2011 9:27 pm
by Charlie100
Hi, mine has a similar problem, but its not after 15 minutes, its very random. sometimes not seen for about week, but then all of a sudden after a trip and i went shopping or similar the light is on.
I have done some research and it might be either the petrol pump or the filter in the pump.
when my light comes on the power comes back at around 3000 rpms, but the engine light stays on
I don't know about the fault code though
I am tackling the petrol filter replacement tomorrow, but wont know for quite a while if that has solved the problem
Posted: Thu Dec 29, 2011 7:16 pm
by Charlie100
I did the fuel filter change, isn't that difficult, if the high pressure nut isn't stripped like mine was. It feels as if the car runs a bit better, might just be all in the mind but I do suspect it makes it better as the fuel that was coming out of the filter was very dirty. I think this filter was on there for a very long time
R205 for the filter and about 30 minutes and it was done, and R29 for the 7" pipe wrench to remove the stripped nut.
You can replace the nut, its stopped by a lip that make it impossible to remove.
I have taken pictures and will do a DIY post on it
Posted: Sat Dec 31, 2011 7:59 am
by robwright
Thanks Charlie had changed the fuel filter about 3 weeks ago and had also removed the fuel pump in the tank to clean the screen . I ended up disconnecting the battery overnight . Since reconnecting it . No fault code and it's Been running fine it's even idling properly . Starting to suspect that cat might be blocked as once after gunning it hard for 30 min the cat light came on together with eng light . Waiting to hear from fellow 3.5 owners if cat can be removed without causing a problem .
