Freshman
Water leak
Hi all,
I've got a strange water loss problem:
I check my oil and water every morning.
So 2 mornings ago I noticed that the filler tank was suddenly empty!
So I filled it up and kept checking it through the day and it did not go down much. Also no white smoke or any rise in temp or loss in performance.
So last night I made a note of the water level and trues-bob this morning it was empty again.
So I figured the filler tank must be leaking.
(All along I also checked the rad level and that was full each time).
So I blew into the filler tank but can't feel/hear a leak.
Upside down in the pool, no bubbels visible.
So I have it filled with water sitting in the kitchen now to see if it leaks but for the last hour - nothing.
What could this be then? Or is it just leaking VERY slowley?
Freshman
Re: Water leak
Took it to Silverton this morning for a pressure test and they found a leak on top of the Rad casing.
Still under warrantee from the Rad over-all they did :)
