Special tools: long arms to reach the oil filter
either get a filter tool for loosening the oil filter or punch a hole in the filter and use screwdriver to loosen it but make sure you have the correct replacement filter first.
apply thin smear of new oil to new filter rubber, tighten by hand nice and good.
For sump plug use ring spanner and tighten lightly - use common sense, sump plug is there to plug the hole not to keep things together so you only need to tighten to the point where it wont vibrate loose.
fill, start and let run 30secs, switch off and let oil drain to sump for 30secs, check level and top up again, start and let idle for 1min, switch off and check levels. if needed top up, go for short drive to warm oil and check levels again when engine at normal temp.
Makro is currently selling Delo400 @ R189
MThompson wrote:Hi All
My pajero has done about 7000km since the last service (Mitspro) and I would like to change the oil and oil filter between the services myself. I'll be switching to Delo 400, from what I've read, this is the oil of choice.
I will do the oil change this weekend as we are leaving for a 3000km trip in 2 weeks time and I would like to have fresh oil in the engine. I will also inspect air filter and other fluid levels. Do check them often, so they should be in place.
From what I've gathered, get oil (2 x 5l), oil filter (from stealers), sump plug gasket (from stealers). My biggest concern is fitting the oil filter and sump plug.......is there a way to ensure I don't over tighten it? I don't have a torque wrench. I guess...stay away from a ratchet, to easy to apply to much torque?
O and, do I need special tools for the oil filter?
I would appreciate any advise.
