Is this normal?
I noticed that my water in the resevoir is black. Its this normal out its it something I have to worry about?
2009 Pajero 3.2 LWB GLX
OME Suspension
ARB Bumper
FR Roof Rack
Christoff
Re: Is this normal?
hallo i would suggest you drain the water and replace with a mixture of anti freez and water, the mixture should be a greenish colour, if you still have a problem you might want to think about seeing your mechanic.
Re: Is this normal?
Is it oily?
Sent via iPad & Forum Runner
Re: Is this normal?
I must go and check, not sure if its oily.
OME Suspension
ARB Bumper
FR Roof Rack
Re: Is this normal?
Its not really oily, it smells like coolant.
If I want flush the radiator, what coolant must I buy and how much?
OME Suspension
ARB Bumper
FR Roof Rack
barneymutt
Re: Is this normal?
Degrading rubber hoses will turn your water black.
Check the overflow hose.
You won't notice it in the radiator because it will mix and flow away.
Re: Is this normal?
I think I will replace the coolant fluid, what is the best make to buy and how many litre.
OME Suspension
ARB Bumper
FR Roof Rack
Re: Is this normal?
caltex extended life coolant is great. Mix to instructions with distilled water.
Just be sure all the previous coolant has been flushed properly as some coolants create a gel when mixed together that blocks radiators, small passages and heater matrixes.
