I have a 1998 Blister Fender ,engine's been redone,about a 9000kms ago...everything was going ok .But recently started to hear a running water sound inside my car while driving,it usually starts around 2500rpms and onwards.Ive checked oil, water etc. and everything looks ok...no loss of power,no leaks.also checked aircon,fan....no problems! Do you guys have any ideas whats causing the noise?
sounds like you have air in the coolant system. The bubbling you hear is the water and air flowing through the heater matrix.
Next time you park after a drive, park the vehicle with the nose up as far as possible.
Let it cool, fill the radiator with distilled water and see how it goes.
Other than that check that the drain plug for the A/C on the firewall in the engine bay isn't blocked.
WillenH
Did you solve the noisy water issue?
I have the same problem.
Rob
Rob
