Hard starting Diesel
Posted: Tue Jul 17, 2012 10:25 am
by DAHavenga
Hi. I have a 2005 3.2 DiD Pajero. It always started within a second of turning over. Suddenly it takes 10or 15 turns to start and it sounds like the starter motor is really struggling. Once it starts there is no problem with power or idling so I’m thinking that fuel system is OK. Checked the battery and it looks fine. From 12.6 v it drops while cranking to 9.5 and comes back up to 13 v very quick after starting. It recently had it’s 180 000 kms service at Mitspo so I’m sure all the filters etc are good. There is also no difference hot or cold so I’m thinking that the glow plug is not the issue.
Is there a compression release valve on the 3.2 that could be sticking? Any help would be greatly appreciated.
Re: Hard starting Diesel
Posted: Tue Jul 17, 2012 10:33 am
by craigdre
I had the same problem, it sounds like the battery isn't supplying enough juice, turns out nothing wrong with the battery, my starter motor packed up. Hope that not the case for you, cost about R12k from the agents. Good luck!
Posted: Tue Jul 17, 2012 10:40 am
maybe you can save the starter if you can manage some tools
See my starter service thread here
https://www.4x4community.co.za/forum/sh ... p?t=114007
before
after
Posted: Tue Jul 17, 2012 10:48 am
by jaco_n
Having the same issue. Had my starter motor redone, issue came back again. They tested the starter, battery, etc all fine. They suspect the glow plugs but none in the country so will wait till my next service.
Workaround : turn the ignition and wait for glow plug light to go off. Switch off the ignition and switch on again waiting for the glow plug light to go off. Engine starts almost instantly
Posted: Tue Jul 17, 2012 11:06 am
by DAHavenga
Hi. Thanx for the replies. I think I'll start with the starter.
Posted: Tue Jul 17, 2012 9:27 pm
by dwinter
I had the same issue a while back - it was the starter motor. My local auto electrician refurbed the starter (new brushes etc) for about R1500 I think.
