Freshman
V-belts not turning
Hi all,
My wife arrived back home minutes ago with the bad news that there is no power steering.
I went to check the fuild which was all fine, also no broken pipe or so visible.
Then I stared the car and noticed that the v-belts were all standing dead still.
I switched her off and moved the belts by hand and tried again - this time they moved very slowly.
I take it that one of the belts lost it's tention.
Is it ok to drive to the Mack (about 3km away) like this tomorrow morning?
Pierre
Renier
Re: V-belts not turning
Have you find the fault yet? If not, I think your crank pulley is broken.
if the v-belt isn't turning than the following items aren't working
- power steering pump
- a/c pump
- alternator
- viscous fan
I wouldn't recommend driving it.
Freshman
Too late now :)
Turned out to be a small little pin/shaft on the bottom gear driving the fanbelt which caused the belt to freewheel.
They had to strip almost the whole engine to get the gear out and replace with a new one. Eish!
Fixed now
