Page 1 of 3
Knocking noise coming from the front end/wheels, HELP?
Posted: Mon Oct 15, 2012 6:54 am
by tsdoran
I recently bought a 2002 3.5l V6 Pajero from Japan. I sent it for a major service to see what the knocking feeling was that wa coming fromt the front end/wheels, we thought it might be ball joints but cant seam to isolate where ts coming from.
Please advise on any thoughts on this issue.
Thank you so much.
Re: Knocking noise coming from the front end/wheels, HELP?
Posted: Mon Oct 15, 2012 7:39 am
Check your stabilizer links on the anti roll bar
Sent via iPad & Forum Runner
Posted: Mon Oct 15, 2012 10:37 am
by tonton
The ball joints may feel tight, but may be dry - make sure it is well greased.
Are your wheel bearings OK?
Posted: Tue Oct 16, 2012 12:14 pm
by tsdoran
thanks very much.
I will get those loked at soon and post back the story
Posted: Sun Oct 21, 2012 12:23 pm
by Oubaas
I had the same problem with a 2001 model. After replacing the ball joints, lower control arms and steering rack, we found the problem to be a left front shock. The tested the shock, and it was in perfect condition, but had a knock. After I replaced the front shocks, problem was solved.
Posted: Sun Oct 21, 2012 3:28 pm
by Gemaskerde Tuinvurk
When does the knocking sound manifest? When the wheel articulates (e.g. Over speed bumps) or under normal level road driving?
Posted: Mon Oct 22, 2012 11:45 am
by cawleydavid
I am having the same problem, very frustrating as I have just had ALL the suspension bushes replaced and expected that to do the trick. When I went back to the guy who replaced the bushes, he seemed to think the Shock Absorber was the culprit. Will let you know how I get on!!!
Posted: Tue Oct 23, 2012 1:09 pm
by Stephan
I replaced front shocks and stabiliser links. The knocking sound still occurs when hitting rumble strips, small bumps or rocks on gravel roads.
I will get the ball joints and anti roll bar bushes lubricated and report back.
Posted: Tue Oct 23, 2012 3:21 pm
lubricating is unlikely to eliminate a knock. A knock is play somewhere.
Posted: Tue Oct 23, 2012 4:36 pm
by Nismo
Like 4e said. Check stabiliser link. I had the same issue with my 2005 model.
