I have a question(or two)from smart Okies whom has knowledge in this area,for some of you probably will be silly,but for me the answer will be very educative.
I purchased a 12 volt cooler(COLEMAN POWER CHILL)for my longer trips to keep cool things on the road.
Can I keep connected the box on to the cigarette lighter?while the engine is running.Will it use up my battery power?
The second Q is,because this unit is not coming with a main connection,or transformer
In the "mode d`emploi" the fabricator advise to use a battery charger thru a 12v battery otherwise the heaven fell down,and the cooler`s motor get damaged.It seems to me, it is rather complicated way to solve the problem
Best regards to all of You
Peter
