The Sunroof on my Gen3 has stopped "Working"
When you open the sunroof it used to open all the way (automaticaly)
Now when you open the sunroof it moves about 3-5 cm and then stops. you have to do this over and over until it is open or closed.
Any help with this?
I think it might be a relay or a seting on the ECU?
There's a procedure for a re-learn of the system,not exactly sure but it cured my roof opening problem a while back.
I recall something in the manual about the procedure.
This is an old post but I thought I would reply, as I had this issue today. (And sure someone else may experience it in the future)
All I did was to hold the open button, until the sunroof opened all the way. I let go of the open button, and pressed it 'open' again. This time it moved back another few centimeters and I heard a loud click. I closed the sunroof and it all worked perfectly from there. Everything is back to original settings.
I found the writeup below on antoher forum. It did not work for me but I thought I would share it regardless:
SUNROOF INITIALIZATION (LEARNING MODE)
- Press the sunroof OPEN switch, and continue to press this switch until the sunroof is in the fully-open position.
- Pressing the sunroof CLOSE switch will move the sunroof approximately 30 mm (1.2 in) toward the closed position before stopping automatically. Repeatedly press the sunroof CLOSE switch until the sunroof is in the fully-closed position.
Press the sunroof CLOSE switch until the sunroof is in the full tilt-up position.
- With the sunroof glass in the full tilt-up position, depress the sunroof CLOSE switch for about 3 seconds until a clicking sound is heard from the sunroof ECU.
- Continue to depress the sunroof CLOSE switch and move the sunroof glass lid to the full tilt-down position.
- Depress the sunroof OPEN switch once to slide the sunroof to the fully open position.
- Press the sunroof CLOSE switch to make sure the sunroof glass closes normally.
Hi all, is there a manual operation, at all, for the sunroof? I know my luck, will most probably break half open or closed!
Thanks for posting this avaneeden. My Pajero's sunroof motor came loose, made a moerse grinding noise. Found the problem, tightened it. Now having the same problem, will try this fix and report back.
