I want to install a EGT
1. where do I buy one?
2. which one do I buy
3. how do i install it
what temp should the gen 2 2.8T run at 750 degrees C?
thank you
found this info for other users
http://www.madman.co.za/madman_technical.htm
R1300 for the base model
also see
http://www.landyonline.co.za/
also see
Mgl avionics engine monitor. Put one in my 2.8 pajero. Very happy
I've also been looking to fit an EGT. I haven't decided yet which one to buy and where to fit.
Also, I would rather like analogue than digital, but not sure which is the better option.
Seen some analog gauges at Autostyle......not to sure about quality and accuracy though.
I think Steve's Auto (tune up specialists) have then, maybe with multi point readings.
Mgl avionics engine monitor E2. Search on this forum you will see more details.
Gauge on the left hand side
thanks for the info, that is what my research recommended. i actually removed the manifold yesterday and i am going to check the turbo aswell.
i bought the madman gauge and they say the gauge must not be i direct sunlight, i will have to fit it below the radio.
egt installed this weekend, tested it today i must push very hard in 4th to get the temp to 600 degrees over 4000 rpm
i take it this is a good sign
