Gaurav
Should i change ECU with same engine swap?
Planning to swap my existing 6G74 with another clean 6G74 in my 2 door 3.5L Pajero. Do i go buy new engine with wiring and ECU or do i simply use my old ECU which is already mated with TCU and driving behavior. Thanks in advance.
If you are using the same engine code then you can use existing ecu, connectors and wiring.
Sent from my iPad using Tapatalk because forumrunner keeps crashing on ios 6
