Yellow oil light
Posted: Thu Apr 11, 2013 1:51 pm
by Ryperd
I noticed this morning that the yellow oil light (oil pressure if I am not mistaken) came on whilst the Pajero 3.2 was still running cold. It stayed on for a while and then went of.
The car does not use oil, nor leak any. What can this be?
Re: Yellow oil light
Posted: Thu Apr 11, 2013 3:57 pm
yellow oil light is low oil level
red is oil pressure
NEVER drive the car a single meter if the red oil light comes on.
Posted: Thu Apr 11, 2013 6:48 pm
by Ryperd
Posted: Thu Apr 11, 2013 7:12 pm
by andrew.ashton
If it is a 4M41 diesel this is quite common.
Lots of threads about it.
It almost certainly happened just after you started going up a hill when the engine was cold and went out just after you tapped off after suffering heart palpitations thinking your engine was about to blow.
Add oil to 3mm above the dip stick level mark - problem solved.
Yellow oil light
Posted: Thu Apr 11, 2013 7:25 pm
by Ryperd
Thanks Andrew
