service intervals on DID Injectors
Posted: Sat Jan 09, 2010 6:13 pm
by JDV
At what intervals should the injectors on a 3.2 DID be cleaned, inspected or replaced?
Re: service intervals on DID Injectors
Posted: Sun Jan 10, 2010 1:53 pm
Not sure what the manual says but I have had mine tested every 100 000km so far.
Posted: Sun Jan 10, 2010 5:34 pm
by JDV
Hi Cats,
Thanks, what was the condition after 100 000?
Mine is down on power and heavier on diesel(84 000 km) after I ran out of diesel because of faulty fuel gauge ; want to have the diesel pump tested as well
Johan
Posted: Mon Jan 11, 2010 10:33 am
They were slightly out of spec at 100 000km and was replaced under extended motorplan. When I had them tested again recently at 200 000km they were still good and no further work was done. Apparently there is almost only one place in SA that can test the diesel pump and injectors on these DiD engines and that is Alan Black in Johannesburg. They have the equipment to do the tests.
Posted: Mon Jan 11, 2010 1:06 pm
by JDV
Posted: Mon Jan 11, 2010 6:14 pm
by mimmo
Good question, I had my pump and injectors tested by Alan Black at 650,000 km for the first time and they apparently are within specifications. The paj does not smoke and the fuel consumption is the same as when it was new,
approx 10.5 to 11 liters per 100km. I beleive you should only check your injectors if engine smokes excessively or if there is loss of power , excessive fuel consumption. You may find that the problem may be due to one injector only if
your mileage is less than 200,000km.
Mimmo
Posted: Mon Jan 11, 2010 6:40 pm
mimmo wrote:Good question, I had my pump and injectors tested by Alan Black at 650,000 km for the first time and they apparently are within specifications. The paj does not smoke and the fuel consumption is the same as when it was new,
Mimmo
Can you elaborate on what fuel you used and whether you used 2-stroke or additives every now and again?
Posted: Tue Jan 12, 2010 10:31 am
by mimmo
I have always used 500ppm diesel ( mostly BP ), additives never used , fuel filter replaced every 20,000km ( original mitsubishi filters always used ).Engine oil used is Caltex delo 400.
Mimmo
Posted: Tue Jan 12, 2010 11:51 am
If that isn't a good testimony for mitsu design then I don't know what is.
