From Entabeni,
Recently,when uploading a sequence of photos individually and using the 'inline' button and adding a comment to each, they appeared in reverse sequence.
Surely it should be possible to use the 'shift' or 'control' key to select a sequence of photos from the same or different folders and have them appear in the desired sequence, adding comments to the photos afterwards, just before submitting the post. If so, how!
Thanks, Entabeni.
Entrabeni, when you look at the final post (after hitting submit), you'll see they should not appear in reverse sequence. They only appear that way in the post text. Please check. You can use the test forum for this. The selection of multiple photos in sequence is a software restriction, and I'm not about to spend the time (not that I have the skills) or money doing this when a new version of the software is on the cards.
