Strange Missing DiD problem
Posted: Mon May 05, 2014 10:48 pm
Hi Everybody.
I'm new on the forum and hope someone have some useful information.
I own a 2003 SWB 3.2 DiD manual Pajero and have been having a terrible missing problem almost since I bought it 5 years ago.
At first it wasn't as bad and only manifested itself once in a while, but lately its been getting really bad to the point that I want to put a match to the vehicle.
If I start the car when its cold it runs just fine.
It has a lot of power and runs really smooth.
When it warms up after I have driven it for a couple of km's it will develop a slight roughness in the engine.
Almost like it's firing random cylinders.
When this happens it makes a lot of black smoke and it will start jerking.
It just keeps getting worse till the car becomes undrivable and sometimes the engine light will come on and the car goes into limp mode.
Then the only cure is to switch it of and let it stand for 15 to 30 min.
When I start it will be better or even 100% again for a while.
I have noticed something over time.
It seems to be much worse on hot days. 15 degree days or colder and sometimes no problem at all.
25 degree days or warmer and it will happen a lot sooner. sometimes within 5 min driving.
Also making it work harder like towing or driving up a pass for example seems to aggravate the problem, which makes me think its somehow related to a sensor that deals with temperature or something.
Another peculiar thing that I've noticed is that the rev counter starts acting up when the miss presents itself.
It will read lower and lower till its indicating 1000rpm at 120km in top gear. when the engine light then comes on the rev counter jumps back to the correct reading, but then the car is in limp mode and I have to stop and switch off in any case.
I have disconnected the boost air temp sensor and driven it without any change.
What is the purpose of this sensor if unplugging it has no effect?
One of the specialists wanted to rebuild my injectors that's has only done 30 000km's.
I think if was an injector problem, the car would smoke and miss all the time and not only when its hot.
Any thoughts someone?
Has anybody come across this before?
I love this car but its driving me nuts.
Estienne
Estienne
