My Paj is at again!
Hi Guys,
My 3.2 2003 paj is at it again! For the past few days I noticed that when the engine is at working temp,she starts hunting (that business of the rev counter going up and down when idling) but other than that she has been running fine.
On my way to work yesterday,all hell broke loose when while doing about 80KM/H, the sound just changed from that sweet cheeky pajero diesel roar to sounding like an old Isuzu diesel :shock: (i drove one for 3 years and i loved it then :lol: ).
I felt a slight loss of power. looked for a safe place to stop. popped the hood and obviously i could not see any thing wrong :?
I drove around just like that for the rest of the morning. Later during the day i swapped the the injectors around. I was also thinking probably it could be some sticky valves so i gave each valve a few sharp taps (no technical reason for this), closed it up and started. The noise was still there and now it was like its firing only on two cylinders! :(
Did the exercise again and this time around she fired okay but was still sounding like my old ISUZU.
On my way to the office this morning, when she started she was back to normal (quite) then a KM or so down the road the noise came back for another KM and then it disappeared.
Stopped at the office, all seemed normal except for the hunting! :?
Anybody got an idea what she is Up this time around?
Note: She is about to spoil my christmas! :x :x
If it has moving parts, You can always figure out how it works. Not applicable for solid state hard drives. :) :lol:
Re: My Paj is at again!
Mileage on the diesel pump? Any fault codes pop up when you do the DIY fault code check where you earth one of the pins on the OBD type plug? Might just be something silly like a dirty air and diesel filter? How close is she to next service?
Agree with Cats, if not that, check gearbox oil level..
3200 Tdi GSL 2001 Written off
3500i A/T 5Dr 2001 Sold
3.2 Di-Dc GLS A/T 2008
Herman 6609
As n Pajero ry,ry hy lekker,maar as hy staan,dan staan hy in sy @#$# in.Ek moet 21 werk dae wag vir n seel MR 967673!
Herman 6609
After a small oil leak on gearbox and 4x4 lights flashing
