Just signed up here as it seems to be the most informed place for the Pajero/Shogun 4m41 engine.
Mine died on my whilst on the motorway the other day. It had for a while a timer position sensor problem. I was waiting for the two sensors (at 12 and 3 o clock) to be replaced, but had only got round to changing one. In any case it made no difference.
Any how this is what happened, driving home the car began to loose power and jerking quite violently. If it was a petrol car it felt like a fuel surge where you suddenly loose all fuel pressure, anyway, I noticed it was producing a lot of white smoke, and just made it off the motorway and the car rolled to a stop and died - the problem started about half a mile before the junction.
Any attempts to start it just caused a momentary rev of the engine and then it would die again. In the end I was towed home.
Fuel level is fine, and if I crack off an injector and I get fuel. My feeling is the timing is out.
I read around some of the forums on this, and it seemed to be pointing to this sensor:
I have removed this sensor and the plunger bit that sits in the middle of it seems ok, but the little sleeve bit that sits at the end of the plunger has about 0.5mm of movement - is this normal? And in any case I don't think it would stop it running?
So any suggestions where to go here? I fear its a write off, as I really dont want to spend £1500 on a new pump...
