Portos
Engine light on Gen4
I have a 2007 Gen4 "GLX" DID with 281000km. I have serviced ot for that last couple of services all according to the book. However, the engine light came on this week. How can I read the error codes without a scanner/machine. The procedure for the Gen3 by which you ground terminal 1 does not seem to work. The engine light does not blink. Just stays on. Also how does one reset it? Please, any advise?
Re: Engine light on Gen4
Hi Protos,
Mine did something similar at 158,000km. Took it to Mitspro in Centurian and they stuck a laptop on and found it was the diesel filter needing a change. this was after they mentioned to me before diagnosing that it was probably the filter. Maybe yours also needs a change.
Anyway, you'd have to get a laptop connected to it it seems.
GC
Portos
Hallo GC
Thank you very much. It was the problem. And I did take it to the Friendly guys at Motomid Middelburg who helped me.
The question is still where one can find a connecting cable to connect a PC to the ECU? Alternatively where to find a wiring diagram to build one; and then the software?
Kind Regards
That is Great News! Glad it worked for you. on the cable - I'm not sure the cable is your only problem. The diagnostic software is also hard to come by (I've heard anyway) and very expensive. I was told R57k for the package that lets you diagnose and adjust settings. So to me it's worth the odd few hundred bucks once in a while to just take it to a proper workshop for them to run through issues (only two found in 7 years) and reset the small-quantity-learnings settings. (??)
Cheers,
GC
