My Gen2 3.5 has started getting oil in the radiator reservoir.
Not a thick sludge but it is black. Started getting hot but not to the red line if I slow down and turn the aircon off.
No water in the oil that I can see.
Is my head gasket toast?
Hi Simon, it has been a while
I saw your similar post on the other side as well and I agree that a good starting point would be the oil cooler.
Here is my experience from my student cars (last time I had that problem):
Oil to water can be a one way affair when the breach is where the oil pressure wins the battle.
The oil should get churned up into a grey emulsion by the waterpump. Check inside the radiator.
Could the black stuff in the expansion bottle be from a failing radiator hose?
