Cruice control
Posted: Mon Apr 04, 2016 8:03 pm
by tiny hitge
Hallo, 3.2 DI d 2003 It works but the moment the road has some hills the moment it kicks back a gear (auto box) the auto cruice kicks out completely and needs to be activated again.Seems to get worse after some driving.Has someone got an answer thanks Robocop
Re: Cruice control
Posted: Tue Apr 05, 2016 12:05 pm
by LowRange
Re: Cruice control
Posted: Tue Apr 05, 2016 12:57 pm
by Dirty Boy
Yup, I get that.
It seems a common problem.
I have determined that mine does it in the following conditions:
Laden ie heavy
Dependent on the speed that you set the Cruise relevant to the degree of uphill ie if its very steep and you want to cruise at 120 it will kick down.
This is understandable as it would kick down even if you weren't on cruise.
After a while of it now trying to maintain the set speed in the kicked down gear, it then kicks out the Cruise as it cant maintain that speed.
