dash lights
Good Evening
so driving home now, going very slowly i noticed the following dash lights remained on and there was a noise from the engine,
red oil can
orange oil can with a wiggly line under it
battery
AT temp
anyone got any ideas on what could be causing this?
i am fast loosing my confidence in this vehicle
regards
Mark
broitman
Re: dash lights
oil in engine missing
engine overheating
Re: dash lights
First of all I would try and establish if it is a real mechanical issue first. ie check the engine oil level / have checked or check the oil pressure / have checked or check the battery / have checked or check the transmission temp (eg hand held infra red meter or just get under and feel if it is actually that hot) / have the engine noise listened to by an experienced party. If you are in or near Pretoria I can offer to help.
The warning lights you mentioned are pretty much isolated (WRT their warnings / problems), so my guess at this early stage it might well turn out to be an electrical problem. When one gets random warning lights all coming on together it can be a bad earth in some cases or an electrical short circuit. It can be something as simple as a rat chewing the wiring.
Let us know.
