Namib
V6 3500 GDI will not start
Hi Forum Members
I really hope you can help me.
I have a SWB Blister Pajero with the 3500 24 Valve Petrol motor.
The intake manifold was very packed with soot (from the exhaust gas recirculation?), so I removed it and cleaned it. At the same time replaced spark plugs and fitted a new fuel pump.
The vehicle has 170 000 km.
When bolting everything together again, I switched the cable loom for the plugs around - I think...
As I tried to start it backfired a bit but no start.
I then changed the wires to the spark plugs the right way round, but it will still not start. Just cranks.
I pulled out a plug, and yes, it sparks.
Disconnected the fuel pipe, fuel is pumping.
Put a generic Diagnostic on it, all seems fine.
I am at my wits end - any ideas what causes the vehicle not to fire?
Ingo
Re: V6 3500 GDI will not start
Look on the forum for the firing order, and check against what you have in place. Best place to start.
Namib
Hi Members
4 weeks later, and unfortunately not much help from the Mitsubishi dealers - apart from trying to sell my very expensive parts with a 6 weeks delivery time - the problem was the Petrol Micro Filter inside the High Pressure Pump.
Filter removed - all problems solved, the Pajero running like clockwork.
As expected, Mitsubishi SA/Imperial told me they do not sell this filter - the offered a complete new high pressure pump at about R 40 000-00 - very nice :-)
Any idea where I can get this miniature filter?
Overseas it is about Euro 9-00.
PS: It seems that most dealers and Independents are scared of the GDI motor????
