Good day all.
I bought myself a 1997 3.5 24 Valve DOHC with blown head gaskets. Had the heads overhauled and replaced all the gaskets but when I try to start her up she starts idles for about 2 seconds and cuts out after that she refuses to restart and you need to leave it for about an hour but then does exactly the same.
I've looked at the following: got spark and fuel checked all the filters and fuses with no luck the only thing that I'm not sure about is the plugs on the injectors got 3 x black for the one bank and 3 x green for the other but it might be swoped around.
Any advice?
Sent from my E5823 using Tapatalk
