Which one does what for you?
What would you want more?
why?
I thought this will be an interesting discussion.
Torque is the twisting force the engine produces.
Power is the speed at which this force is done.
Think about a big wrench attached to a nut.
Torque / force - The longer the arm and the force applied, the higher the twisting force applied to the nut.
Power / work - The quicker the twisting force can be repeated, the higher the 'work'
In an engine, the two are directly related: ( http://www.rri.se/index.php?DN=28#060 )
Power [kW] = Torque [Nm] x Speed [rpm] / 9549
Torque [Nm] = 9549 x Power [kW] / Speed [rpm]
With a gearbox (a torque multiplyer), you can get the required torque by using the right ratio.
For me? Give me torque, as in a good TD! (Large capacity V8 petrol engines give the same, at double the fuel consumption).
Extremes:
Ship (diesel) engines: very high torque, but low revs.
F1 engines: very high revs, but low torque.
Extremes:
In short it is like race horses compared to cart horses
I have a Calibra that produces 243kw on the wheels enough to get to 267k/h in less than 13 seconds but it is not made for working, the power is at high rpm and shifting the 6speed box is like stirring a cup of coffee. Hook a trailer behind her or load anything more than the day's shopping and she becomes lazy.
A diesel pajero would be happy with half those kw but produces more torque at lower rpm and that is the reason why diesel is in theory better for 4 X 4 applications. It would idle over obstacles that a petrol motor would burn cluches on.
Your petrol 3l produces about 40% of those kw in a 6 cyl monster and would stand no chance in a straight and level race other than to bring the trailer at the end of the meet but try and load the pajero on the trailer and get the calibra with all its kw try and tow it on level surface forget about any incline, you'll have more smoke than Mick's jet car
Henk Bannink
C'mon Pikanini,
You knew what your dad was going to answer here, look at what he bought.
I'm more of a fence sitter and believe that both torque and power is needed to get the job done properly - simply because we operate our cars in extremely varied conditions. A low kw - high nm motor is not going get you through the Namib desert, but really enjoy climbing over obsticles and ofcourse vice versa for a low nm - high kw motor. That is why we sit here on the Pajero site, both the 3.8V6 as well as the 3.2DiD deliver well on both counts. Obviously each one with a bit of a bias towards it's own strong point.
I'm definitely a torque fan having driven my brother's 1.9 tdi and my dad's v10 tdi.
I'm more interested in the technicalities of what is torque and what is kilowatt with regards to weight, gearing and what each's benefits are?
We have a nice "saying" in German for exactly that question - but I can't translate it:
"Hubraum statt Heckspoiler"....but it matches perfectly
Maybe Kai can help in the 3rd word to translate...
Direct translation = Cubic capacity instead of back spoilers
In South African = " There is no replacement for displacement"
Henk Bannink
That phrase was coined in the days of the American V8 engines.HBannink wrote:Direct translation = Cubic capacity instead of back spoilers
In those days they were the only engines which could produce prodigious amount of torque at low rpm, albeit at the cost of kW and fuel economy.
Today's 3l TD engines produce as much torque at low revs, with the benefit of very good fuel economy.
I had a Chevy 4.3l V-6 in the Gen1 before I fitted the Di-D. Both the torque and kW figures were very similar (the Di-D winning in the torque department).
The Chevy uses just about double the fuel the Di-D does.
No contest.
Unbelievable - you can just install another engine in a car w/o any official technical proof of compatibility, i.e. that the brakes can handle the increased power ???4ePajero wrote:...I had a Chevy 4.3l V-6 in the Gen1 before I fitted the Di-D. Both the torque and kW figures were very similar (the Di-D winning in the torque department).
The Chevy uses just about double the fuel the Di-D does.![]()
The TÜV in Germany would never allow this....not even in Europe such modifications would be allowed w/o an official technical check.
Sorry for the OT digression, but this needs a reply.MR2-Blue wrote:Unbelievable - you can just install another engine in a car w/o any official technical proof of compatibility, i.e. that the brakes can handle the increased power ???4ePajero wrote:...I had a Chevy 4.3l V-6 in the Gen1 before I fitted the Di-D. Both the torque and kW figures were very similar (the Di-D winning in the torque department).
Brakes don't handle power, but only speed (or the reduction thereof), which was not higher than previously.
I know what I do, and I would not have done anything which would have been unsafe.
My conversion would have passed any test in any case. It looks like a factory fitted engine.
Leaving intelligence to the government only, can have very negative consequences.
Mark one against Europe, and one for 'backward' South Africa, for a change!
