Seat belt not retracting
I have a Pajero DID 2011 and the drivers side seat belt does not retract fully
Any recommendations as where to buy an replacement ?
Thank you
Johan
Re: Seat belt not retracting
Try these two:
Henk De Klerk (Pretoria North): +27 (83) 306-1848
Mitsubishi Spares: Kameeldrift Road, Pretoria East - (081) 385-1662
Thanks Kurt, will do
Toyotavan
Hi Kurt
You can tighten the seat belt clock spring,
Remove the b post trim remove seat belt assembly,
JUST THE MECHANISM WITH THE BELT WOUND UP,
remove spring cover screws hold the cover tightly as the spring will try to escape wind it up 2 or 3 turns, I have done this a few times and it worked perfectly
If the spring escapes I don’t think you’ll get it back together so be careful
My seatbelt is just fine thanks
