2012 Pajero Sport (manual) Oil leak between gearbox and engine
Posted: Sun Nov 07, 2021 8:43 pm
Greetings! I hope someone out there might be able to share some experience.
I have recently joined the club, with a used but relatively low mileage 2012 Pajero Sport (manual). During the recent purchase, it was noted, on the DEKRA report that there is a leak between the crankshaft and the engine. I requested Mitsubishi to do a 101 point check, and they recommended to replace the crank seal. The seller had the oil cleaned up by their mechanic, and the deal is that if it continues to leak, we cover the cost 50/50.
There are two points of view, don't fix it if it's not problematic. The second is along the lines of fix it before it causes damage.
I'm curious if it is common to need to replace this crank seal after 100 000km/10 years?
If there is a light leak/sweating, is there any benefit to delaying on the replacement, e.g. is it likely that one can get another 10-20 000km without needing to do the replacement?
I need to make a call on this in the next week or 2 if I'm going to get the dealer to come to the party and get this work done this month.
