Wiring for touch screen radio and Bluetooth module
Hi All,
New to the group, have a Pajero swb 2008. I have changed the radio to the touch screen unit in later models. I want to connect the Bluetooth module but need the wiring diagram as my Pajero does not have the wiring harness, so I need to tie into the existing system. Any help with the wiring will be great thanks
Re: Wiring for touch screen radio and Bluetooth module
Good day Brett.
Your request is a bit vague. What exactly do you wish to connect and where do you want to connect it to ?.
You say you have a blue tooth module, what is it exactly ? is it a stand alone ?, what touch screen radio do you have, as most of the newer units on the market already have blue tooth built in. I'm a bit lost in what you are trying to achieve.
I recently fitted a double din unit, non touch screen with blue tooth built in and they biggest problem was finding somewhere decent for the microphone as friends said it sounds "echo ee". Trial and error solved that one.
